The Rv8 Rebuild Is Well Underway...
Shaft
Hi peeps...
Well, the winter mods time will soon be here so i'm busy beavering away getting
the old 3.9 RV8 ready for when the car comes of the road.
Thought i'd post a couple of pics and a link to the rest I've got in my usual Photobucket
account.
Funnily enough, I'm slightly excited about getting the old 8 pot fitted and running. 8)
http://s575.photobucket.com/albums/ss195/shaft_Zero/Replacement%20engine%20rebuild/
On its way apart....
On it's way back together, only improved!...
MMhhhh, Piper 285 and anti pump lifters...
Been down the garage this evening doing a bit more on the RV8...
Cam timing all set now and all bolted up complete. Duplex Timing Chain adjustable at the Crank Sprocket
Then back to the heads and now sorting the Exhaust ports to remove the stupid humps and bumps that Rover heads all have. The valve bowls are already done so just a case of matching to the gasket (except the bottom, it needs a step to assist in stopping gas reversion) and blending through to meet the bowls. One done, Seven to go!
Check out the amount you can remove from standard... :db:
Well, managed to grab another few hours down the garage this evening and have now got one head complete with all the valves cleaned, dressed and lapped into their seats.
Shiny things... i reckon i'm part Magpie! :crazy:
love it
always fancied some sort of V engine, the noise is just incredible. what sort of power are you expecting from this?
Thanks. :drinks:
From past experience of building Rover V8's this should be putting out @ 260bhp with the spec I'm building it too.
If it Rolling Roads at that I'll be a happy bunny as 260 bhp should equate to @ 250 ftlbs of Torque with the porting and cam set up.
Guest MarkB
260hp!
holy moly, what spec are you building it to? i'd have been better off with one of these than supercharing my pinto i think!!
or just buy.... http://www.ebay.co.uk/itm/CHEVY-GEN-III-LS1-LM7-V8-Small-Block-Engine-Drag-Drift-Kit-Car-TVR-Rover-Cobra-/150825369574?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item231de47fe6
plug and play
260hp!
3.9 serpentine block, bores honed, balanced crank, match weighted rods, piston tops cc'd, new big end and main shells,
new rings, stage 3 heads, combustion chambers polished and cc matched, thin head gasket raising compression to 9.75:1,
Piper 285 cam, Rhoads anti pump lifters, Duplex timing chain, new 1.6:1 ratio rockers, rocker pedestals shimmed to achieve
correct pre load on the lifters, offenhauser dual plane inlet manifold and an Edelbrock 500 carb.
Phew.... That's a lot of waffle!! Just got the exhausts to sort then... That's a worry for another day though.
